RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
I can only find a couple discrepancies, but one thing is that it says that the 10C is only capable of Mode 1, Mode 2, and 2 Programmable. Not true....it does all 4. Also, it says that Futaba has 40 steps of trim resolution. Futaba's trim resolution is adjustable up to 160 (I think). Also, they limit the 10C to 10 rates...but I'm pretty sure it's 15. Also, it claims no airbrake-to-elevator mixing. Untrue. Ail-to-rudder and rudder-to-aileron. I'm not sure which, but I'm sure it has at least one of those. Not false, but not completely fair: It says that there's no "Hovering Stick Position" settings on the 10C, but you can adjust both individually. Slight untruth, just aggravating.
I'm not completely sure about these, but I'm pretty sure these are accurate.
