RE: Bob Cat Copy Falcon 120 Jet
I notice that in post 3480 as on my Falcon that there is a gap at the canopy front. Has any-one had theirs blow off in flight??????? Should it be necessary to close the gap so air pressure will not tear it off or??????????
Also for those doing rail mounted retracts, I was able to use the existing rails etc. using Springair's and was able to shorten the gear(5' belly of fuse to ground) by moving retracts back and the nose gear wheel well foreward as far as possible. Used a 2 1/4 ' wheels and bent a new nose strut of 3/16 mw.
Now installing ecu, brake control, fuel tank, rec , batt's etc.
Dave
