Carburetor problems
On my O.S. Max 40 engine, the throttle lever retaining screw came loose and prevented my engine from operating properly. After tightening the screw, it worked fine for one day. The second time I went to fly, the engine stopped shortly after starting and also in mid-air resulting in a dead stick crash with no damage. Why does the carburetor not have the same opening every time I move the stick to the low position? Sometimes the opening is smaller then needed to idle the engine and when this happens, the engine shuts down to disastrous results.
I contacted O.S. and they said that I need to either flush the carburetor with fuel or get a new one. Does this make sense? It was hard to get it out of them, see a little difficult to work with.
Thank you for your help in this matter.
