RCU Forums - View Single Post - Carburetor problems
Old 06-16-2010 | 10:56 AM
prgonzalez's Avatar
prgonzalez
Default RE: Carburetor problems
LokiDog,
If your carburator does not have the same opening at different times without having changed anything in the transmitter in regards to throws or trim, it is likely that you have a problem with the servo gears. The gears might be jumping one of two theets in both directions. I had the problem myself one time. I remember that idle was either too fast at times and too close at other times. Replacing the gears of the servo resolved my problems.
I hope it helps.
Pedro
