RCU Forums - View Single Post - Any info on Comp-ARF Revolution Pro
Old 06-16-2010 | 08:55 PM
MTK
Default RE: Any info on Comp-ARF Revolution Pro
ORIGINAL: rustywallace5934
Matt and Andy,
Thanks for the explanation. The link was a great help as well. What would be the best adhesive to use to glue this crutch in? That goes for the servo mounts as well. I've never owned a composite airframe, so not sure what to use.
Kevin
There are at least a couple types you can use and both require that you sand the fuse insides as well as you can and as far back as you can. In general laminating epoxy is pretty good at not blooming but one can't guarantee non-bloom. So you at least want to clean the surface as well as you can with 93% IPA from Walmart.
Epoxy mixed with microballoons is the first choice and gorilla glue the second.
Good luck
