RCU Forums - View Single Post - Rolling flight line box~Cheap!
Old 06-17-2010 | 02:51 PM
krashkart
Default Rolling flight line box~Cheap!
I have had the typical wooden tool boxes before back in the 70s. I wanted something different this time, and preferably cheaper than what they get for the typical RC Boxbox.
For my needs Ihad no use for the power panel they sell you with the typical box andI will just make what I want on my own.
I found this Stanley roll around tool box at Wal Mart today. http://www.stanleytools.com/default....le+Work+Center
Take a look at the pix of this thing. The bottom opening slides down and will accommodate two bottles or cans of fuel(and they will sit flat with room to spare) with additional space to spare. Getting them in and out is no problem with the opening. The top is a typical tool box of course which should hold all I need and then some. I am getting older and I thought this would make it nice and compact and I can roll it if I want to.
The best news is that Wal Mart carries this locally (here anyway) for $22.88 which makes it a bit of a deal as far as I am concerned. And to me that makes this a whole lot better than that flimsy $20+ (or more)wooden box that you glue and nail together.
For my use I will put a jug of fuel in on one side, with my starter in the middle and a battery just bigger than the little 7 amp they want to sell us on the other. I will lengthen the fuel lines and wiring accordingly to get it to the model on the table at the flight field although as the one I use I could put it up on the table as our club has very generous space there.
I can mount a hand or electric pump on the outside or insideif I wish as this is sturdy enough to support that type of stuff.
I thought I would just share what I found that we can make our own out of and maybe customize it just a little.
