RE: Cooling factor ??
Funnily enough the field where I used to fly control line has high tension power lines running behind it and every time your eye caught then in the background you would involuntarily take a step back from them even though they were at least 300m away!
But yeah, your right I would have to simply run the prop into the ground - but hopefully in the inverted position to minimise the damage caused.
