RE: T 28 Trojan control problem
That sounds like a low voltage reboot. Either that or you have a bad servo or a bad component in your radio system. If you got 4 good flights then this started happening, I'd definitely suspect the battery. What are you using, and are you checking it with a loaded meter between flights?
