RCU Forums - View Single Post - Radial engine experiment: What do you think?
Old 06-18-2010 | 08:16 AM
Patxipt
Default RE: Radial engine experiment: What do you think?
Tom, how far away from the tip of the exhaust stack is the oil tubing?
If it's too far inside, that could be enough for the exhaust pressure to be higher than crankcase pressure and keep part of the oil from venting properly.
Did you run it already without being connected?
