RCU Forums - View Single Post - Radial engine experiment: What do you think?
Old 06-18-2010 | 10:31 AM
Kmot's Avatar
Kmot
My Feedback: (24)
Default RE: Radial engine experiment: What do you think?
MJ: I agree it 'looks like' fuel dripping but I think it was just very hot oil.
Patxipt: The tube extends down quite a distance, about 1" from the end of the exhaust outlet.
*Edit: Officially official: I just measured it. 1/2" from the bottom of the exhaust pipe outlet.
I am beginning to wonder if a straight tube in the flow of gases blasting by it actually creates a suction on the tube?
BTW, how does the angled cut on the end of the tube create more suction?
I understand how a true venturi tube works, but this setup could never be a true venturi even if I made the tube into a true venturi shape because it is closed at one end.
I have not run the engine again. Maybe later today.
One other thing, this 2nd version collector ring sounds a lot different than the first. I have no understanding why. I am guessing maybe the straight down 6 o'clock exhaust outlet versus the curved rearward 8 o'clock outlet.
