ORIGINAL: Roger M
Mine is similar at elevators 35mm, ailerons 16mm and rudder at 25mm and the CG is set at 155mm from LE of wing.
Roger
After thinking about it, your spot on. I use the 50mm on elevator for take off because i have fitted a half litre tank in the space behind the canopy and in front of the turbine hatch that empty`s first, so it allows me to start up, taxi out and get a couple of circuit`s before it starts using the main tanks. I switch to a lower rate after take off which is probably around the 35mm mark.
I also have the CofG at 155mm.
cheers
john
