RE: LiFe Rx battery
Hi,
An electronic engineer at our field really likes these batteries for his big gassers. He uses them on the RX and ignition. He keeps track of the MaH on each recharge/discharge. This is the only way to tell how much flight time a pack has. As said before these packs have a very flat voltage curve. A volt meter MAY not be a safe measure depending on the power requirements of the given plane. Timing the recharge if you can't measure Mah. Keep a record.
