RE: Echo BME twin
Cranks, see pic.
Case? Square bar stock with a round hole. Make the ends with the bearings seperate and to fit the round hole. Machine all necessary holes, dowels, threads, and such. Remove all unecessary metal?
Assembly, Is there enough room to slip the crank with con rods on it into the case from the front or rear? Then the pistons are attached after?
