RCU Forums - View Single Post - seen somewhere about MG995 servo from Tesla?
Old 06-19-2010 | 02:10 PM
opjose's Avatar
opjose
Default RE: seen somewhere about MG995 servo from Tesla?
ORIGINAL: jester_s1
No, I haven't used any of them. Here's where I got the idea that the gear were too heavy.
[link=http://www.rcmodelreviews.com/mg995review.shtml]http://www.rcmodelreviews.com/mg995review.shtml[/link]
Interesting review though I had to laugh a bit.
The guy was correct in complaining about the fraying wires... but the "unsupported wires"... from the controller board to the motor... c'mon...
He needs to get a bit real... he's talking about a 1" length or less... SHEEZ!
The motor should never move if properly mounted, nor should the circuit board. That would have been a much better and more important point of review. What does he think would happen?
Those broken wires were NOT the result of vibration, rather a bad joint and a poor assembler craming things into the case.
I would be far more worried about cold solder joints, poor soldering, poor deadband or recentering... etc.
IMHO He's focused on the wrong thing..
I haven't seen ANY "overshoot" problems even with the older servos.
The gears simply do NOT have enough inertia to cause the problem he has stated...
A lot of what he is saying is pure speculation...
While I've used a bunch of the servos on different planes as well as the newer ( and better ) versions.
I've seen others target the actual problems and benefits correctly elsewhere.
I agree with those negatives and positives... e.g. centering is not as precise as more expensive servos, etc...
But for a sports flyer most of the problems are non-issues... and the later version addressed this stuff anyway.
