RE: Engine Help!
thats unlucky about ur engine, if im not mistaken if u were going to put that engine in you would need to change the engine mount, use the clutch bell from the corsa and a couple of other things i reckon this engine would prob be ur cheapest alternative to the original cen engine
Force .46 Engine ABC Rear Exhaust & Pullstart (SG Shaft)
Part No: 4476550
In Stock
Available by Special Order £94.50
its available from modelsport uk hope this helps but i would speak to them first just to make sure it fits without having to change anything cause if you did have to change heaps of stuff like you would for the k5.9 you would be as well fitting an lrp zr30 spec 2 engine
