RE: My newly built Dumas Ace Sloop
Hi BGnome, your boat looks better than mine, nice job!
your not hurting by missing the dumas tiller arm wire as its pretty flimsy I think 1/16 K&S wire would be better. You can probably just solder it onto the rudder. If you want it to last you may consider getting some thin brass sheet and recut the rudder from the brass as my rudder was a thin tin metal. The brass tube for the tiller arm I beleive was the same diameter as the spreader arm for the mast so 1/16 should be a perfect fit....Dont forget to use those little S hooks to connect the line to your screws on the deck. If you need more you should be able to find them over at Home Depot or Ace hardware store.
Cool thing about Dumas boats is you can trace out the parts onto paper and build a fleet of the things if one wanted to...Its an easy boat to build isnt it?
