RE: LiFe Rx battery
Sorry for raising this issue again, but how do you charge this battery? I recently bought the Hobbico version (3.3V nominal voltage x 2cells, 3.6V x 2 fully charged). I havent discharged it yet, just received it couple of weeks back. But when I put it on the Triton2 EQ balance charger, it says " Batt V too high". Is this a common problem caused by fully charged battries? I couldnt get the battery to discharge "a little"...its 3200mAh and it hasnt discharged even when I kept it connected to the RX for 8 hours (I just kept it connected, didnt keep moving the servos as I worry I will wear them out before the battery)
Ameyam
