RE: Everything Radial Engines
OOPS sorry. The FF-240/320 carb. You will be very pleased with the improvements. Understand that the midrange is adjustable to by rotating the aluminum ring between the black portion where the servo linkage is and the carb body. One of the carbs had this way off and the engine would quit in the midrange! Easy to fix though. -Tom
