RE: Engine bogging at 1/4 throttle
how far are your needle valves turned out from being all the way in. the two needle valves work together to give a good idle and power but if the are not set right you can get it running good in certain rpms and bad in others. the best way to solve the problem is set both needles back to factory recommended position and then adjust from there otherwise you will be chasing good running spots all over the settings and never get a good overall running engine
