RCU Forums - View Single Post - evolution 46
Thread: evolution 46
Old 06-20-2010 | 05:29 PM
Lou Crane
Default RE: evolution 46
Chris,
There's been a lot of discussion about the CL-only EVO 36s on some CL sites. Much comment that that engine, at least, prefers fuel with low or no castor oil in the fuel 'package.' Of course, a total oil percentage around 20% is indicated.
That engine reportedly likes to carry a bit more load than many "modern-metal" engines. (We often run CL Stunt engines at higher RPM on flatter pitch props, if the engine does better that way... The EVO 36 is said to want a bit more pitch and diameter. )
...Raises the question - what fuel are you using? Old fuel runs funny. Fuel for ABC/etc engines used in older iron engines may cause damage. Iron engine fuel in an ABC-etc. engine may have too much castor, and may gum up the the precise fit cut into it.
The other points to date - plugs and gaskets - may help a lot. The CL .36 may not be designed as nearly like you 46 as would have experience with it be useful for you... Just a few other areas to consider, if that's the situation.
Luck
