RCU Forums - View Single Post - Covering visibility help
Old 06-20-2010 | 09:55 PM
  #35
ro347
My Feedback: (13)
Default RE: Covering visibility help
ORIGINAL: SeamusG
Emmm - and you posted this thread in the ''beginners'' forum - yea, sure
I don't understand the ''adhesive side up''.
I think I heard you say that you laid the violet on the green (green adhesive side down and the violet adhesive side up) so that you could cut get a perfectly matched butt edge. If you did, did you do this before applying the green to the white base? I like the of floating the small trim pieces with liquid (yea, I know, Windex does not activate Ultracote adhesive so we don't need ta go into that issue), butting them against the green, squeegee out the liquid then heating them up. I tried that once but was unsuccessful in removing all of the moisture so when I hit it with real heat bubbles occurred. Gotta admit the the piece that I floated was much bigger than your trim strips.
Thanks for sharing.
I added some pearl blue to the otherwise boring top view ...
I'm thinking that some ''over-n-under'' trim pieces could be treated like you did - resulting in a single ''trim'' layer. In my case, cutting the blue over the red so that the blue doesn't overlap the red but lies in the red.
Im learning as I go...what cand I say!
I like the updated scheme you posted.
I did both teh green and purple adhesive side up while setting it all up. If you have glass surface to work on, you can do adhesive down.
