ORIGINAL: fw190
Having more cell count (higher voltage) would require less amp for the same needed result you had with 10s. The 80HV will run cooler than before.
yup, you are right! This is still new to me but I'm learning. I did the calcs and find that the 2300 mAh packs put out 69 amps. 14S yields 46.2 volts(loaded). total watts equals 3188 which is equal to 4.25hp on a 14 pound airframe!! That assumes I did the math correctly...this should be fun
