RE: Static vs Flight Current Draw
The power calculators will give you an estimate for your initial setup and prop size selection, but you still need to use a Wattmeter to get more accurate measurements of your actual setup.
I've seen a few guys compare static vs. in flight current numbers, and all the comparisons I've seen differed only by only a few percent.
Given this, I wouldn't let the static Wattmeter readings exceed the limits of your components.
