RCU Forums - View Single Post - 10 CHP Model programming
Old 06-21-2010 | 07:46 PM
ALWAYSPDG
Default 10 CHP Model programming
Hi Bax.
I had asked you a while back about transferring my model memory from a 9CHP to my 10CHP. I currently have a CAMPac installed in my 10CHP Tx making a total of 20 model memory slots available. 14 of them are used right now. Slots 19 & 20 are used on the CAMPac card. The 10CHP is a 2.4 system. The 9CHP is a 72 MHz system. I believe that slot #19 & #20 can be erased on the card.
I want to take my brand new 2.4 receivers and just replace the existing 72 MHz receivers in the airplanes and helis that are on the older 72 MHz system.
Can I just remove the servo connectors in the older receivers and put them in the same channels when I install the newer 2.4 receivers? 1 to 1 , 2 to 2, 3 to 3 , 4 to 4, etc...
Do I need to change any of the model programming when converting to the newer 2.4 system?
Thanks in advance for the help ,
Mike
