will this battery work on either my hobbico 180 or the sullivan high tork
<ul>[*]Type: Lithium Polymer[*]Capacity: 2100 mAh[*]Voltage: 14.8V nominal[*]Connector Type: T-Style Ultra (14 GA Wire)[*]Balancer Type: Align/E-Flite compatible (XH)[*]Number of Cells: 4 [*]Weight: 221g[*]Configuration: 4S1P[*]Dimensions (WxLxH): 37 x 105 x 29mm[*]Maximum Charge Rate: 2C (4.2A)![*]Maximum Continuous Discharge: 20C (42A)[*]Maximum Burst Discharge: 40C (84A) for 3 seconds[*]
http://www.amainhobbies.com/product_...Ah-Starter-Box[/list]
