ORIGINAL: Batty33Res
Hello, yes just like in your picture
Hey again mate,
Adjust the control arms to tilt the swashplate forward then. You can remove some of the permanent FF with the trim on the Tx. See what eventuates.......
Peter[sm=shades_smile.gif]
P.S. The next thing to do is relevel the swashplate by eye - then loosen the screw at the center of each servo arm, pull the arm to the head of the screw and move the arms orientation to be closer to 90ยบ than it was before. Beware the spline on each will stop you putting exactly where you want........
Don't forget to re-tighten the screw
NB THIS IS ALL WHEN THE SWASHPLATE IS LEVEL BY EYE - a great starting point[sm=49_49.gif]
