RCU Forums - View Single Post - starter battery
Old 06-22-2010 | 08:28 AM
jester_s1
Moderator
Default RE: starter battery
That battery is likely the minimum that will work and still last for a reasonable length of time. A lot depends on how you use your starter. Bumping a well primed .40 isn't nearly as taxing as starting a bone dry 1.20. Just keep the charge topped off and it should be ok.
