[*]The correct prop/gearing should slow the motor should turn at 80% to 50% of its unloaded rpm.At 80% rpm it is running at its efficient,at 50% rpm it is delivering maximum power.If it is outside that region then change the prop or ratio to suit.[*]With a suitable prop measure the current.[/list]
...any esc is fine but it must be electronic with no relays.
