RCU Forums - View Single Post - PT80 Turbine- Please help
Old 07-23-2003 | 07:52 AM
cairoman's Avatar
cairoman
Default PT80 Turbine- Please help
Nir,
You have to calibrate the pump so that it will work per specs. Look in the Projet ECU manual on how to calibrate it. It usually takes about two minutes for the whole process, then everything will be alright. A friend of mine had the same problem with his Behotec 130 and he solved it this way.
Regards,
Chris
