RE: Earthquake 3.0 Advice
Glow plug was good, it's the igniter that kinda sucks. charge it for 30 minutes it lasts long enough to start it twice then dead.
What are the factory settings for the carb on this? This must be a newer carb, the idle screw is recessed into the carb on the backside (between the engine block and carb) unlike the ones I have seen where they are on the front. the HSN looks the same, so I set it back 2 turns from all the way clockwise, but the LSN is different, if i set it flush, it's about 5 full turns out from counter, and it is definately WAY rich. I tried 1 turn out from counter and it was too lean. AGH! If I didn't have to wait 1/2 between tries I'd prolly be done by now... maybe...
