RE: MAN reports on Airtronics SD-10G 2.4Ghz radio system
I just got one of my planes set up with my SD-10G. I haven't done a range check yet but I was reading a few post about if your using FH1 modulation you can't get more than 15 paces away from the plane before it's out of range but the plane flys fine. Unless I missed it, I only read about getting 30 paces on a range check in the manual. I'm using the 92824 8CH receiver on FH1. Unless this was an isolated case, can someone shed a little light on this please ???
