Hi Dave,
It's under the "Start" menu on your Hand Data Terminal. Go to "Start Gas Adjust" and dial it down to 60 and you should be set.
Hope this helps!
Chris
ORIGINAL: dw_crash
Hello John,
I have check my ECU and manual. I can't find the gas setting mentioned in your post;
"Adjustments were pretty simple:
Set glow plug to 32
Set gas valve to 60"
Where and how do I get to the gas valve setting?
thanks
Dave
