ORIGINAL: Beachcomber
By pure definition, CCPM is electronic. And mechanical collective pitch control is Non-CCPM.
Please re-read my earlier post - ANY heli that uses the swashplate to mix in the two types of pitch change (up and down for collective & tilt for cyclic) IS a CCPM system.
If all of this swashplate mixing movement is the result of mixing in the TX - then it is an electronic CCPM (eCCPM). If all this mixing movement is from mechanical systems below the sawshplate, then it is a mechanical CCPM system (mCCPM).
