RCU Forums - View Single Post - engine puffs in air...
Old 06-23-2010 | 12:04 PM
  #38
Switch_639
Default RE: engine puffs in air...
input noted... I will try the stock muffler again with the 13x8... its leaking at moment... so I don't use it... the 128 was with BCM pitts muffler btw... made enough RPM's... only recently have I tried the rossi... the stock one I must fix the leak and then also try it again... I only had 2 runs with the 12x8 and rossi and the engine is still really new... so I would be disappointed if the bearings are already failing...
