RE: Replacing receiver antenna
If there is good wire outside the case then its also very simple to solder and shrinkwrap a splice there and you avoid the delicate circuit board. Just use a good quality stranded wire typically AWG 24 or 26, I prefer the thinner 26.
Do plan for 39 inchs or in the case of Hitec which by default are close to forty one inchs.
John
