RE: new 7C Programming questions
If you have the 7C FASST transmitter, you can do both. You use the Flaperon function for dual aileron servos, and the Ailevator function for dual elevator servos.
If you have a 7C transmitter on the 72 MHz band, it has the Flaperon function only. To get dual elevators, you use a p-mix, but you won't have trim on the slaved channel.
