RCU Forums - View Single Post - 10 CHP Model programming
Old 06-23-2010 | 01:53 PM
Bax
Default RE: 10 CHP Model programming
If you convert an existing transmitter to the 2.4 GHz FASST system by installing the transmitter modules, you just plug the servos into the slots in the receivers that correspond to the channel they need to be. The channel order won't change. However, when in doubt, you move a stick and try servo slots until the servo's plugged into the correct slot.
