RE: 12FG - using LD and RD to control rates
The above description doesn't actually give you dynamically-adjustable rates for your dual rates or exponential rates. It's just setting up conditions to be activated by a knob or slider. You can do the same thing with switches...you are just stepping through different fixed settings. To fine-tune the rates, you have to go into the AFR section and then alter the values.
There is no way to dynamically adjust rates or exponential settings. They can only be set in the AFR sections. You can, use conditions on a slider or knob so that different conditions can be turned on as you move the knob or slider, but those values will be fixed, and you're just stepping through them. You cannot set a knob or slider to be a fine-tuning adjustment for rates or exponential and dynamically alter them in flight.
