RCU Forums - View Single Post - KingTech K-80
Old 06-23-2010 | 02:02 PM
  #173
marquisvns's Avatar
marquisvns
Default RE: KingTech K-80
ORIGINAL: Rush!
Barry,
I didnt know you could actually use diesel... and i am wary of using other than whats recommended in the manual as it may void the warranty?
Also diesel is messy vs. kero and JA1. being that kero and jet a-1 are very similar in properties, i thought Kero would be cheaper to use for flushing fuel tanks and fuel systems with kero, do the initial fuel pump run in and the initial test runs on kero before i moved to A1.
Also, i sort of read that you can use synthetic motorcycle 2T oil now instead of Turbine oil? I have some BP turbine oil here but if i can run synthetic 2T oil thats alot easier to find as well.
Thanks again!
Rob
Rob, I understand it isn't in the manual, but not to worry, if you or anyone like to use diesel, we'll have you covered. As far as synthetic 2 stroke oil, again, if anyone would like to use it please drop me a line through email and we'll cover you 100%, we appreciate all the data/experience gathered.
Barry
[email protected]
