RCU Forums - View Single Post - CCPM?
Thread: CCPM?
Old 06-23-2010 | 05:18 PM
Rafael23cc's Avatar
Rafael23cc
Default RE: CCPM?
ORIGINAL: Beachcomber
In addition to all the good stuff already posted, I'll add this.
Much of the confusion in the term CCPM (well defined by Rotor) is what some call mechanical CCPM, which IMO does not exist. Not trying to start an arugment, just trying to clarify the subject for Rcag. If you are controlling collective/throttle blade pitch with a seperate channel, and it is not Mixing with the cyclic blade pitch signal, then there is no CCPMixing going on.
By pure definition, CCPM is electronic. And mechanical collective pitch control is Non-CCPM.
Do a search on the Concept 30 line of helicopters. Specifically the Concept 30 DX. on that helicopter the swashplate DID NOT MOVE up and down like the helis we have today. The collective imputs were archieved by moving the washout base up and down, the swasplate remained stationary. THAT is a Non-CCPM helicopter. I believe there are a few 400 clones that use a similar design, so you might be able to find one and see the difference.
Rafael
