RE: 12FG - using LD and RD to control rates
Steve,
You are correct. The "Fine-tune" adjustment of the mix allows you to adjust the amount of mixing percentage "on the fly". This is usually used to fine-tune the interaction between two different functions that get mixed together. However, you can use it to make an adjusment in the amount of throw...or rate. It doesn't look like it can be used to adjust the curve for exponential, though.
