RCU Forums - View Single Post - Battery Choice
Old 06-24-2010 | 10:55 AM
elan120
Default RE: Battery Choice
ORIGINAL: DaveL322
ORIGINAL: elan120
Dave,
That sounds like a good prop to have. Is it available to purchase? I know PT has one in this size, but not sure if yours is different.
Kevin
The specific prop I am running is not commercially available (sorry), but the only real benefit vs the APC is the reduction in weight (which is pretty substantial on the 21''+ props). I've also run the PT Models 21x14CF (available from F3A-Unlimited), and it performs very similarly.
Regards,
Dave,
Thanks. My experience is similar regarding the weight, but experiencing better power output with slight improved RPM, throttle response, and lower noise, which I believe is coming from lighter weight and firmer tip. Good to know that PT has similar performance.
Kevin
