RCU Forums - View Single Post - MSR self stabilizing
Old 06-24-2010 | 04:43 PM
DenverJayhawk's Avatar
DenverJayhawk
Default MSR self stabilizing
is there a way to make the MSR stop attempting to level itself after you release the right stick from forward flight? For example, if I push the stick forward and hold it for forward flight, as soon as I release the stick to neutral, you can see the Heli attempt to put in up elevator or reverse control stick which makes it climb initially.
Can it be setup where it will continue the forward motion without trying to self level after releasing the right control stick?
