RCU Forums - View Single Post - carb conversion question
Old 06-24-2010 | 11:26 PM
Andrew_S's Avatar
Andrew_S
My Feedback: (12)
Default carb conversion question
I have a aerovate engine with a p o s chinese carb. It's got the pulse (?) line from the engine to the carb. Now I have a walbro carb, wt-324 with no nipple for the line. Will the carb work like it is and I can just block that line off? Also the walbro has 2 brass tubes, 1 for the supply line, it goes to the seat assembly and the other one just goes internally. I guess it was for the primer bulb. If I block this line off will it work?
Thanks in advance........
