RE: Official HPI MT2 Thread
Just a quick update on my issues. I received my order today and installed the new fuel tank and servos. The issue with the fuel leaking onto the chasis was absolutely a faulty fuel tank. The new tank provided a more air tight seal and after running a couple of tanks through the truck there was not a drop of fuel or oil on the chasis. Problem solved. Also, the Hitec servos made a big difference in the steering department. My only issue was the screws that the servos came with didn't have long enough threads and fell out on the third tank. I'll have to go to the hobby shop tommorow and get longer screws. I would use the screws that came with the truck but they aren't machined and the new servos take machined screws. Finally, I was able to get the brakes working much better. I adjusted the servo location at neutral and that combined with the more powerful servo did the trick. I am just trying to finish up tuning the engine and of course getting the new servo screws and it should be good to go. Thanks again for all of the help.
Matt
