RCU Forums - View Single Post - Another AE .15 problem
Old 06-25-2010 | 07:28 AM
DarZeelon's Avatar
DarZeelon
Default RE: Another AE .15 problem
Dood,
I believe this is your engine:
It feeds on a mix that contains plenty of oil and has a shielded front bearing (i.e. not sealed)...
It should leak some oil; especially if it has a rather loose fit of the crankshaft in the crankcase (tolerances accumulate)...
I don't see it as a problem, but if it ever becomes one; you can replace that front bearing with a double contact-sealed version of the same size.
It should be a 10x19x5mm 6800-2RS bearing, which should have a C3 clearance.
