RCU Forums - View Single Post - Official Parkzone Extra 300 thread
Old 06-25-2010 | 10:53 PM
  #62
badflyboy
Default RE: Official Parkzone Extra 300 thread
This plane was not designed properly. I had 2 landings and twicw the gear ripped out. CA the first time second time hot glue. Problem is second time the slot where the metal wishbone wires goes cracked and now the gear wont stay in. If so many people are having these problems then horizon should have not went with this gear setup. Im also having trouble getting the cg correct. I had to dremel out the battery area to fit in my turnigy 2200 battery. Im not sure if the stock battery is heavier because with the turnigy all the way foward its still tail heavy.[ul]
