RE: Weatronics an extra servo needed
Ross,
Virtually everything is possible with the Gigacontrol software. Even complex mixers from one channel to other ones.
Take some time to read both user manuals for the 35/72 Mhz units and 2.4 units. You won't regret the time spent.
You can offset the neutral for each servo by moving the whole curve.
A well programmed 12-22 units is nearly impossible to saturate. However the multiplex functions from Futaba/Graupner will soon be supported with will potentially increase the inputs to 26 channels an outputs to 36 servos ( 44 with the 12-30 unit ).
