RCU Forums - View Single Post - Top Flite B-25 ARF (Tecnical, tips, suggestions)
Old 06-27-2010 | 08:58 AM
  #2499
Speedracer2112's Avatar
Speedracer2112
Default RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
ORIGINAL: djstar39
Hey folks,
I was using the rubber grommet but the pin gave way.
Rubber Grommet? I didnt know there was one. Sounds like a great idea, where can I get one?
ORIGINAL: djstar39
What are you folks doing for extra axle pins? Do you buy them directly from Robarts? From Tower Hobbies? Make your own?
You can call Robart and they will ship them to you. They are about $6 each. They are the mains axel cut off so you can get those also and cut them yourself.
ORIGINAL: djstar39
Have any of you had to replace the spring hinges in the nose door? Did you drill out the existing ones or start over next to them? Also, where can I buy the hinges?
You should be able to grab them with some needle nose plyers and twist them out. I have a set somewhere. If you want them you can have them.
SR
