RE: Unofficial
the best thing to do it first drill out the hole in the housing from 2mm to 3mm then replace the rubber seal with a 3x10 mm rubber sealed bearing . the only hard part is opening up the pilot bushing in the stater housing from 2mm to 3mm . after u do all that and replace the shaft coupling for the new shaft . your ready to go
